So I’ve been PMing with @Hedges a bit about SMA systems. Very grateful for the contributions and I think I’d like to expand to others for more insight as well.
SMA Sunny Island does not seem designed to handle Lifepo4 banks. To mitigate, it appears that many utilize the REC BMS for lithium comms
Every thread I’ve found so far, shows this working with AC coupling with Sunny Boy.
Hedges brought up the sunny boy as well, so I guess maybe I need to take this under more serious consideration
Unfortunately, my pea brain can only absorb so much, so often. And so it’s still stuck on DC coupled systems
My thought was 2x SI 6048 with 2x midnite classic charge controllers. Midnite has a communications adapter to allow SI and classics to communicate.
What I can’t seem to find is, will this design integrate with the REC BMS? SI + midnite + rec = success?
Secondly, would the midnite classics be the most logical choice due to the comms adapter or is that not necessarily relevant if the BMS communicates via CAN with the inverter. How does it communicate with the charge controller at that point?
