KevinC_63559
I've been using the Sunwatts website as a bit of a reference for things like $/watt, physical size, origin source, etc.
I'm becoming concerned as I drill down farther. For instance https://sunwatts.com/550-watt-znshine-mono-bifacial-xxl-solar-panel/ is clearly advertised as a bifacial panel, but the description and back image show a white backsheet. So these can't be bifacial right? Which description should I believe? This holds true for a lot of their "bifacial" products.
Is this just sloppy web editing? I've noticed other minor issues as well, like the table showing a minimum order of 10, but the description showing 31...
What should I believe?
