The Solar Pergola Project - Repurposing a pergola I once built to power our home
Watts Happening
I call it like I see it.
Long story short: I built a big steel pergola four years ago and finally realized I should throw solar panels on it. Scroll down for pictures, it's still a work in progress. If you're bored and into solar like I am, read the back story.
Back Story
Years back I built this pergola in our back yard, a neighbor had a terribly kept back yard and this helped us not see it plus provided some much needed summer shade and great place to hang out in the winter with a hot tub, fire pit and Alexa controlled copper mister system I built. At 20x22' it's 440 square feet of roof space, our local jurisdiction requires a permit on anything over 200 square feet, and just by chance, I fought and won that battle. The 4x4's are all 1/8" thick, aka .120 wall, except for the horizontal one with a large cantilever, it being 3/16ths (heavy as hell). Four posts are four feet into the ground with 200+ pounds of concrete, one is bolted to our patio. That cantilever was only done to eliminate a sixth post going straight down into our already existing concrete path. I cut the shape of our state out of 1/4" plate to act as a gusset and shorten the cantilever. I tried to go the route of permitting but the city was being a REAL pain, I asked if they could help me understand their definition of square footage, as the eves of my home don't count as square footage etc, so I was struggling to understand if I needed a permit. They couldn't come up with a solid answer, and I told them if they couldn't point to law that defined it for my structure I was going to build it regardless. If I had built it out of wood they'd have happily stamped and approved it in house, but by going with significantly stronger and more permanent steel, they required stamped engineering drawings and a "certified welder" or to optionally have all welds magnetically inspected.
So, I began building it and was immediately red tagged, I openly told them where I lived and expected it. I was probably 80% done and invited the inspector over, he had already guesstimated it at being 400 square feet, I told him the dimensions and welcomed him in. We went out back and he was like, "yeah, this is going to need a permit". I then explained my interpretation of the law being that if you wrapped a string around the posts, anything inside that would be considered square footage, anything outside was "eves". He agreed, then measured, then said, "I can't believe it, it's 197 square feet, in 30 years of working for the city, this is EASILY the largest legally un-permitted structure I've ever signed off on". We shook hands, he asked for some pictures for his buddies and went on his way, great guy I've dealt with numerous times since.
It's now been maybe 4 years and I'm going through another permitting process of adding a Sol-Ark, SOK batteries and (10) 395w panels on the house, playing the same games as before. The only sticking point this time is them wanting "stamped engineering plans stating the rafters can handle the weight", to which I ask whom in my neighborhood has changed their rafters to accommodate solar panel load, even with the exact same floorpan and more panels. They knowingly answer "nobody", but then say other homes can't be used as an example. Cracks me up, but it'll be worked around soon enough.
The Solar Pergola
During this time I was sitting outside and thought, you know what, screw it, I'll just throw panels on the pergola and they can't do anything about it. Talked to the city and they basically agreed. It's not an ideal roofline at all, facing about 315 degrees (Northwest), at a 13.5 degree tilt. It won't be perfect, but it's got plenty of wasted space and I may as well utilize it, not having to deal with fire code setbacks that just destroy usable roof square footage on the home.
So I ripped off an 8 foot section of the roof and began stitch welding strut channel on top, about 1.5" of weld every 12", staggered by 6" on the opposite side. The panels will be going horizontally across the channel and it's absolutely overkill having them clamped every 2 feet, but I'll never have to worry about anything falling apart. I'll end up with (16) 445w bifacial panels up there as the new roof, which should certainly help our power demands. Panels will be delivered Monday/Tuesday and will start going up in sections so I can still walk across the old roof to place and tighten them. Then another section will come out etc, it'll be three phases.
For mounting I opted to use the mini rail end and mid clamps from Signature Solar, then removed the bottom piece that normally slots into the rail and replaced it with seemingly hard to find M8 threaded unistrut spring nuts as shown.
My one current question
Would you consider the panels to be safely bonded to the structure under those clamps without any of the little ground/bonding gizmos that can be bought? I spaced it and didn't realize they didn't come with the clamps, but I'm mentally assuming that (8) clamps per panel should be pretty darn sufficient for ensuring the panels have a decent ground to the structure so I can just connect a single grounding wire to the pergola and call it "grounded". It'll be aluminum on aluminum as the panels aren't anodized black, then on the bottom it'll be the aluminum panel touching the galvanized strut channel. I don't want to make it unsafe, but I also don't want to delay and waste time/effort on something that to me, seems pretty darn solid. Your thoughts?
I'll update as I make progress, any questions are more than welcome.
Before the roof removal
Before I extended out wall up, you can see the waterfall that runs in PVC through one of the rafters and dumps into a whiskey barrel that has a pump in it, which then cycles it under the deck (made of recycled hardwood pallets) and back around for another loop. Also Alexa controlled.
Removal and project starting
Forgive the overall mess, it's project time. You can see the conduit going from the back side of the pergola to the garage where the Sol-Ark is. Also note how no part of the pergola is attached to the house, the upper board is cut where the rain gutters are and the rest of that "wall" is a "gate" attached to the house. This was again due to a requirement that the structure couldn't be attached to the house, or it would need a permit. You can also see two of our four mini splits on the side yard. I removed our entire exising HVAC system in favor of them, they've been great.
Mini rail clamp on the left, original nut removed and replaced with unistrut spring nut on the right, and installed into the railing above, looks like it's going to work out swell. Hoping the ridges of the mount help with ensuring a good bond to the structure.
Update 8/31/23
The panels were delivered yesterday and one was unfortunately broken. That said, I was able to get the first (5) installed and connected to the system. The PV wiring from the panels to the outdoor breaker box is very temporary, I won't finalize it until all panels are installed so I can configure the series strings in such a way that they take advantage of shading in the later hours of the day (upper panels on one string, lower on another).
We have in-laws coming over this weekend from out of state so I cleaned up the tools and threw some camping chairs back there. It'll come together over the next couple weeks.
I also finalized the outdoor PV breaker, pulled another set of 12awg wire for the second string and bonded the pergola to the Sol-Ark/house ground. I suppose my only question here is whether someone could argue this 3" of 10awg ground wire is "subject to physical damage" where it exits the conduit at 8' in the air, below a roofline. If you're unaware, a ground wire subject to physical damage needs to be 6awg or larger. Personally I feel that would be a stretch, but I suppose I could add additional protection if needed. I gave the steel a good brushing with a die grinder then immediately installed the bonding wire, I then applied 4 coats of clear coat to help mitigate any rust over time.
Continuation of the original post:
Conduit is also bonded to ground inside the wire trough at the head end with the Sol-Ark pictured below.
Had the in-laws in town for the holiday weekend and did a camping trip so that slowed progress. But I did finish a second row of (5) panels today and got them temporarily connected, everything is working great thus far. I’ll likely be moving the middle panels to the left to have the same size gap on both sides and figure out a solution for said gap. But we’re 2/3’s of the way there!
Update 9/12/23:
Finished the install of the remaining (5) panels, we now have (15) 445w bifacial panels running for a total of 6.675kw. Also added a secondary 50a plug in the garage today. The one on the right has grid power 24/7 so I can always charge my car, the one on the left was added today and is connected to the Sol-Ark inverter utilizing something called “smart loads”. It only provides power if certain conditions are met, in this case I have it set to switch the plug on when the batteries are above 95% state of charge and solar is providing at least 1,500 watts of power. It will automatically shut off when batteries get down to 90%. This is just for testing but what it effectively does is lets the solar system power the house first, charge the batteries second and when there is excess power it automatically dumps it into the Tesla so it’s not wasted, but also won’t let the car discharge the batteries overnight.
Nice!
I would definitely call the panels bonded if they clamp directly to the strut channel, which is welded to the rest of the structure. I personally would call it grounded as well since the posts go directly into the ground. You could still run a bonding wire to your system ground if you feel like it.
Nice!
Hopefully that's everyones consensus, I agree, I think they're well bonded and like that the mounts have some ribbing where they touch the panels, but there is always the argument of surface corrosion getting in the way of that. I find it rather unlikely to happen at all (8) clamps, with aluminum to aluminum, plus the aluminum to steel at the strut channel.
I've already pulled the wire through the conduit and included a 10awg ground I'm currently planning to attach to the structure via a self tapping screw and nice washer with some bite to it. I'll likely do so inside a box and eliminate any requirement for using 6awg wire that is "exposed to damage". I have the wire, it's just annoying to work with compared to 10awg.
That is one hell of a gusset. I have a similar structure planned. I just picked up 400' of 6x2x3/16HSS. I assume you know that unistrut has solar clamps?
Yeah, I already had some of the Signature Solar clamps which were only $1.50 each, then the nuts were maybe $1 each, so all in all it's cheap and should be very sturdy. I couldn't find the unistrut clamps and quite honestly just assumed they'd be outrageously priced.
Using these and the correct corresponding end clamp based on panel thickness: https://signaturesolar.com/mid-clamp-for-mini-rail-silver/
Plus these nuts: https://www.amazon.com/dp/B0BCCDK64K
I'm almost positive those links aren't affiliate links, certainly didn't try to make them one. I have no affiliate relationship with Signature Solar, but I do with Amazon, so hopefully I did that correctly.
Isn’t there a way to check ground quality?
Nice outdoor addition.
I assume you’re talking about whether or not the panels are bonded to the structure? Your most basic test is a continuity test and I’d be shocked if it didn’t check out perfectly. But maybe over time it fades, mayyyybe.
Nice idea and good execution. Same story with the county here, other than anything with a permanent foundation needs a permit.
A patio doesn't need one though.... :cool:
Very cool.
Update:
Panels arrived and I got the first (5) up today. Don’t pay any attention to the hideous wiring, that’ll get cleaned up tomorrow morning, I didn’t want to waste any undue time without knowing how they performed. So far, so good. Hazy day, but I think tomorrow it should be obvious.
That is going to be a big cascade when it rains, are you going to do something to seal the gaps or put something underneath to prevent water coming through?
Yeah, working on the solution.
Fortunately it doesn’t rain all that much in the desert ;)
I had the same problem and what i did is to mount the panels together with 2mm butyl tape between them to seal the gap, and instead of clamping the usual way i clamped them from underneath.
View attachment 165338View attachment 165339
I certainly considered that, not sure what I’ll end up doing. Strength is #1, a bit of leaking is a vast #2.
If I were in Seattle, that’d be a different answer.
Looks like bifacial panels. Since you're in the desert, wouldn't it get really hot when you sit under the panels while enjoying your yard? If you used regular panels, I would assume the vinyl would at least insulate it a bit?
If you don't mind saying, what county/state are you in?
I monitored mine for a while and also put some safety in case it didnt work and they started sliding down ?
But fortunately is a very good system and each panel with 6 independent clamping points with loctite is very very safe. We have tremendous wind in ocasions and it does nothing to them.
As for the gaps and leaking, what about that TV commercial where the guy taped together a boat? I've never used that tape, but I suppose you can tape the panels all the way around. Who knows how long that'll last.
Very cool.
Update:
Swamp cooler, propane heater, wire welder, misters, party lights, a ladder...bring on the apocalypse!
Looks like my yard. Looking awesome.
Really respect the structural joinery of the frame; nice to see design driven by ideas instead of rules. There's a lot to be said for overbuilt when it can be done as a do it yourself.
The moment you finish install of any kind of rain drippage mitigation it will start degrading. The cost/benefit ratio is seriously questionable.
Given that there is no insulation, high dew point events will result in drips from condensate underneath the panels anyways.
Filling the gaps between panels will possibly interfere with expansion/contraction of panels as well as be unsightly, possibly corroding areas that collect dust and debris.
The height of your structure makes it all but impossible to shield against some blowing rain anyways, so you will be planning for things to get wet under it.
You live in a dry environment; things will dry out sooner than what a lot of readers here experience at their location.
Right now you have a clean, attractive install. Gilding the lily by feeding an obsessive/compulsive bent does not serve anyone.
Maybe you can ride with what you've got for a year and assess then?
Much appreciated!
I agree completely. The pergola is located in such a way that rain almost never blows in the main opening, we just don’t get much wind from that direction, but that said, we just don’t get much rain to begin with. When we do, it’s not like we can’t make a conscious decision to simply stay inside.
We’re at 4,500’ of elevation, and per a quick google we have an average of 300 days of sunshine, and 7.48” of rainfall. We’re in what’s called the shadow effect of the Sierra Nevada mountains, we can watch the storms up there, they just don’t come down here much which is great, Lake Tahoe fills with water and we don’t have to worry about drought as often. Specifically where we are, it’s even less often that it rains, we’re just on the side of the city with the most temperate weather if you could put it that way. I would also assume that 7.48” number is highly comprised of snow, we really don’t get much rain, but certainly get snow in the winter.
Initially I thought it would be awesome to sit out there in snow storms, but we don’t actually do it that often and it would accumulate and fill the voids anyways.
I think for now I’m just going to go with it and let it be a shade structure. On the handful of rainy days we can find somewhere else to stand, or just pick a nice place under the many large panels that isn’t dripping, they are all quite big, I think we can make due :)
