Sabi
I have 1240 watt in solar panels.
Up til now I had 720 Watts (sitting on the ground) connected in parallel via two 30A PWM controllers to a battery bank of four 100 Ah batteries and two 100 watt panels on the roof through an additional 30A PWM controller connected to the batteries. The 2 roof panels are now under shade cloth (90% shade 100% UV protection), so they are not doing much.
I recently added panels and changed to MPPT controllers and I now have a problem.
I have two 300 Watt panels going into one 60A MPPT controller, and that one is working fine.
I hooked up two 200 watt panels into a second 60A MPPT controller and that one goes to sleep mode.
When I unplug one of the 200 watt panels (for a total of 800 watts), the second controller goes to charge mode.
Adding anything does not work.
I added the second 200 W panel with a 3rd 60A MPPT controller, and the 3rd one goes to sleep mode; the others remain charging.
I added a 240 W panel instead of the 200 W panel to the second 60A MPPT controller and it goes into sleep mode.
It seems adding anything over 800 watts doesn't work.
I was thinking maybe the four 100Ah batteries can only handle 200 W each, but that doesn't make sense as I want to use some juice during the day, not store everything.
My goal with the upgrade (planning on 1500 W) was to have enough solar to run a small window AC during the day (should take around 1000W) and have some power put into the batteries to have power for overnight.
The 60A MPPT controllers are from a company called Werchtay where tech support doesn't speak english and the sales rep was no help.
Is it possible that the batteries can limit what imput in watts the MPPT Controller allows?
Do I need a different MPPT controller or should I go back to PWM. I know the MPPT controllers are supposed to be UP to 30% more efficient but I'm leaving more than that on the table with the panels I can't use.
I would appreciate any suggestions.
Thank you very much.
