Ford typically leaves it in the glove box from factory for the owner to install...Mine was installed at factory due to having the Max Tow PackageYep...just checked..you are correct.
Now, the trailering module doesn't allow 12V to go to the 7 pin unless it sees a combo of a battery load and your foot on the brake pedal so they now just install from the factory.Ford typically leaves it in the glove box from factory for the owner to install...Mine was installed at factory due to having the Max Tow Package
Supposedly, Progresssive is going to change how it works but not sure if they have done that yet.Ahhh ok well that stinks then I have this : https://wfcoelectronics.com/product/wf-8950l2-mba/
My Hydrastar pump uses power from the on board LFP battery. Can't imagine relying on the 12v supply from the truck to power the pump.The problem with this setup is if you need a constant 12V at the 7 pin which I need for my electric over hydraulic controller. Of course the wire is a 16 or 14 awg wire at the 7 pin so it can't really deliver much current without a ton of voltage drop.
If you have a DC to DC converter the alternator charge voltage will not change the output of the converter. It may change the input current however. Just don't think you are going to supply your 30A DC to DC converter through the 7 pin. You will need to run a 4AWG or 6AWG wire back the the bumper and run it to the trailer through an Anderson connector or equivalent.Mike Sokal has talked about this many times and again in this video....that no matter the DC to DC charger rating with todays vehicles being smart and how they regulate voltage it will always go up and down so even if you have a 30a DC to DC charger you may not always get that 30 amps he also states no issue charging lifepo4 from the 7 pin it just wont be much at all limited to around 5 amps on avg...Isolating is necessary of course on motor homes etc...I love watching his videos on his channel and am also a member of his facebook group. Check him out if you don't know about him,
I have read it has been changed to a 2 stage 14.6 then 13.6 power supply. I don't like it.Supposedly, Progresssive is going to change how it works but not sure if they have done that yet.
On my boat trailer, I don't have a nice big battery to supply my EOH which was the big problem.My Hydrastar pump uses power from the on board LFP battery. Can't imagine relying on the 12v supply from the truck to power the pump.
IIRC the minimum wire was #12 with #10 or #8 recommended. (25 to 40 amp circuit)
For me, I rarely do anything but drycamp so its not really an issue. When I do have shorepower, I typically just turn off the battery and let everything just run off the converter and the battery doesn't even see any charge.I have read it has been changed to a 2 stage 14.6 then 13.6 power supply. I don't like it.
On the new trucks?just wont be much at all limited to around 5 amps on avg.
It's tiny. In this picture I am holding a 16awg wire next to the orange wire which is the 12V on the 7 pin in a 2018 f150On the new trucks?
When I worked at the trailer place 7 was on a 30A fuse I thought? Or is that just the 250 and 350s and/or cab’n’chassis? Big wire is what I saw but that was as couple years ago
On my travel trailer the break away system is powered by the house battery. I believe it was done that way from the factory. Less complicated wiring and if the 12v stuff in the trailer is working my breakaway brakes will too.Yes, you can eliminate the charge from the tow vehicle. There are many different ways that trailers are wired, but for me I pulled the main distribution panel out and found the wire that was coming from the distribution panel at the front of the trailer (where the 7 pin is wired into). I pulled that wire from the connection, taped it off, coiled it up and tucked it back into the cabinet. That works fine.
However, if you use that method, you will have lost the ability to provide power to the breakaway brake system. I retained a small battery on the tongue for that.
totally agreed...that's all trailers with electric brakes. You need some sort of battery to operate them in case of breakaway. The 12V+ power line from the 7 pin would do nothing for you if the trailer broke away.On my travel trailer the break away system is powered by the house battery. I believe it was done that way from the factory. Less complicated wiring and if the 12v stuff in the trailer is working my breakaway brakes will too.
My 2011 and 2018 150 were both 30 amp fuses with that small gauge wire like Bruce has shown above...I can't recall what my 250 wire gauge was but it was also a 30amp fuse as wellOn the new trucks?
Alternator has nothing to do with that fuse size.On my 2017 F-350, fuse 27 for the Trailer tow battery charge relay is 30 amp. The F-150 has a smaller alternator so I could see where the same fuse on it is only 25 amp. But I would check the fuse specification chart in the owner's manual and then verify that by looking at that fuse in the fuse box.
Depending on the model, the F150 could actually have a larger alternator than the F350
Well...I just looked at my owners manual, OEM service manual, OEM wiring manual ....and the fuse in the fuse box...all 25ANo, but if you have a puny little alternator I could see the trailer battery circuit limited. However, given how Ford has been consolidating parts between the F series trucks I would be surprised if it's not a 30 amp circuit on the F-150.
keeps the banjos playing thoughdueling alternators
30 amp is really pushing the limits of the standard plug used by rvs. 25 amps is probably a more reasonable number.On my 2017 F-350, fuse 27 for the Trailer tow battery charge relay is 30 amp. The F-150 has a smaller alternator so I could see where the same fuse on it is only 25 amp. But I would check the fuse specification chart in the owner's manual and then verify that by looking at that fuse in the fuse box.
The limiting factor is the wire size. The F350 likely has a much bigger wire than the F150 and it makes zero difference what the alternator size is.No doubt. A post on the Ford Truck forum indicated that the wires were a limiting factor to how many amps/volts you could expect the trailer battery to see. I don't recall the voltage drop but the amps didn't get much above 20 amps. This was on a truck with the OEM dual alternator/battery setup.
