NobodyOfNaught
- Jan 9, 2020
- 31
I'm considering using a Terminal Cube Fuse on my Lishen Cells wich have 6mm threads however the the Terminal Fuse Block has a 10mm hole and it seems unwise to have so much wiggle room.
I'm considering using a M10 to M6 reducer adapter like this https://www.amazon.com/Fitting-Reducer-Metric-M10X1-5-Adapter/dp/B07FLQPNFG#customerReviews
Has anyone done anything similar, how did you solve this issue?
-Palle
-Palle
