Ampster
Renewable Energy Hobbyist
The way I understand it Lithium is the broad category with LFP, Lipo and NMC as subsets. I supose you could add LTO to that as well.Correct. I'm lazy. I call everything not LFP, LiPo...
I am using industry standard nomenclature. They all use Lithium Ions to transport the energy. That is the hierarchy defined by the industry. What you call Li-ion I think is misleading because it doesn't tell me much. And by the voltage you specified it most likely has Cobalt Nickel in it. Google it, look it up in Wikipedia or Battery University. But don't try to invent your own definition for a type of battery that has been around for 30 years.the problem of doing this is it is misleading.
when you say lead battery, you know the a cell is 2V.
but when you say lithium, it just means there is some lithium in it and that is not very useful.
Li-ion id 3.7-4.25V, LifePo is 3.2-3.6, and other batteries with other form of lithium can have differents specs.
so just consider each lithium type as a class itself.
no , what is misleading is saying you use lithium .
if you say you use Li-ion, everybody will know what you are talking about, the specs, the benefits and the risks.
I would imagine the EV manufacturers have their own logic which seems normal to them since their packs are 300 volts or more. In the case of Tesla even they have evolved because the Model 3 modules are probably 100 volts and five or six feet long. I don't even know what "normal" amount of cells would consist of? In Tesla's case they are using small cylindrical cells and most of the others are using prismatic pouches in their own modules.It seems odd that most of the larger EV packs are not using the "normal" amount of cells.
Sorry i didnt read all your answers but yes u ruined your battery the tesla module is 6s 74p 444 cells its top voltage is 4.2 per 18650 cell x 6 25.2 volts over that you damaged the cells you were at almost 4.7 per cellI have had my Tesla battery running in my solar system for months. The charge controller was in the default setting and the voltage was running 21.4 to 24.4 volts. I was reading the booklet on the charge controller and It has a preprogramed setting for lithium batteries (setting 7). So I switched the setting a couple of days ago. Just now I heard popping sounds coming from my Tesla battery and the battery protector had a code of E1 (Short circuit). The battery is hot in the upper left corner and has made a few loud popping sounds. Did I ruin a $1200 battery by changing the settings on my charger controller and over charging the battery? Anyone have any advice?
I have been doing a lot of research on this, for my own setup. The upper voltage on the tesla module you were using is way to much. I can't remember exactly where I saw it, or the exact figure but the voltages I can remember is never charge above 25.2v preferabley lower 21v to upper 25v. The charge controller you had was set more on the conservative side but by upping the voltage to those settings have definetly doomed your pack.I have had my Tesla battery running in my solar system for months. The charge controller was in the default setting and the voltage was running 21.4 to 24.4 volts. I was reading the booklet on the charge controller and It has a preprogramed setting for lithium batteries (setting 7). So I switched the setting a couple of days ago. Just now I heard popping sounds coming from my Tesla battery and the battery protector had a code of E1 (Short circuit). The battery is hot in the upper left corner and has made a few loud popping sounds. Did I ruin a $1200 battery by changing the settings on my charger controller and over charging the battery? Anyone have any advice?
We haven't heard from the OP since this occurred so I hope everything turned out okay. I also did a lot of research on Tesla modules be cause I drive two of them. I eventually decided on using LFP packs because of the incremental ease of expansion and putting them in parallel.I have been doing a lot of research on this, for my own setup.
You can do the same with Tesla's, just make sure you have active BMS installed to make sure they are always balanced and you never overcharge them. Big thing with tesla's if your only drawing 250amp max from a battery pack there is little chance of damage from heat normally. Adding extra tesla batterys does mean you can up your amps and run 2x inverters easily.We haven't heard from the OP since this occurred so I hope everything turned out okay. I also did a lot of research on Tesla modules be cause I drive two of them. I eventually decided on using LFP packs because of the incremental ease of expansion and putting them in parallel.
So there is a good supply of Tesla modules down under?Adding extra tesla batterys does mean you can up your amps and run 2x inverters easily.
true on the last point, though building an expandable system is more benifical than getting stuck with one that can't be expanded easilyPffffft! You -May- find one somewhere... Maybe, but I'd hate to think of the cost. probably cheaper to go buy a new power wall at $15K.
Electrics are still rare and mainly for those with more dollars than sense here given what they go for and the alternatives. Hybrid Camrys have become the favourites of the taxi industry which means there will probably be a high demand for the battery packs and a high cost to go with it given there will be few if any spare packs that have any worthwhile life left in them.
2000 each + shipping.If he found one, what was the cost?
I know what they sell the 7 Ah toyota batteries for, no way I can see a tesla pack going for anything near a sensible investment that would give any justifyable returns or similar capacity could not be had cheaper.
when you weigh it up over no power bills, it becomes very clear indeed$4300 for a 10 Kwh battery . I'll give you this, you have more money than I do.
Or at least you did have.
I hear you, ROI paralysis, just get what works for you and have some redundancy, if one dies you can keep going till it is replaced.weigh that up with no power bills, you can see the method clearly
