houseofancients
Solar Wizard
hi dan,Trying to get the inverter communicating with the battery, but found no info online, nor did I find anybody who has even done communications from the Trophy Battery to the LV6548. After reaching out to Dan at Trophy, he said that the Pylontech protocol the Trophy battery uses is incompatible with the LV6548.
I bought the battery because in the manual it states it can communicate with Deye (Sol Ark) and Voltronic (MPP) only to find out it does neither of them. I asked Dan to please update his Manual, because that's pretty upsetting.
Now I'm trying to just figure out how to read battery SOC without going outside, opening up with compartment and looking at the battery screen. Expecting to spend another $100 on a Shunt, or something. *sigh*
as i understand , this battery has a seplos bms in it, maybe you can verify this.
if this is the case, that a look at the model number ;
if this states 10c ; this is the (older) CANBUS version, which can communicate with deye/sunsynk/sol-ark, but need a deye firmware version to do so.
this can be requested at seplos support, but i would let trophy take care of that.
it cannot communicate with you eg4/mpp-solar/voltronics inverter
if it states 10c , it has the (older) rs485 version of the seplos bms.
this can communicate with you lv's, but needs to be setup correctly in the bms as pylontec , and you need a proper cable to communicate.
alternatively, you could order the seplos 10e bms at seplos, which supports both rs485 and canbus on the same interface.
if you have multiple batteries you'd have to replace one, as it can act as a master for both the 10c and 10d versions
