KevinC_63559
A wise man once told me that its easier to get someplace if you know where your going. Realizing I'm playing around buying bits and pieces without really having thought out my end-point, or rather, having thought out several end-points and not picking one.
So my current train of thought, in priority order:
1) Need to be able to provide power to my fridge and freezers during outages similar to the 37 hour one we just lived through. Key is that these devices only need power for a few hours a day, but also that most long outages occur during snow storms, with half-day outages due to wind occasionally. Current solution is to use an 1800W portable gas powered backup generator with extension cords - presuming it starts and presuming I was wise enough to stock up on gas.
2) Want to be able to replace three UPSes. They do a reasonable job on short outages, but lost month-old battery packs during this 37 hour one. Alas, they are based on 12V9A batteries, with inherent run time limitations, and don't have charging circuits designed for LiFePO4 batteries. If I just wired, say, all of my 120V stuff to the future battery/inverter system, they become redundant.
3) Nice to have some 12V power for a SDR setup, and similar 12V (all of this refers to my man cave building). 10amps of 12V would be plenty. Would it be legit to just tap across one 12V battery, even if that battery was in series. Feels wrong, like that battery would get out of balance., but maybe not - especially is a full 24 (48?) volt BMS was used vs. individual 12V systems. Suppose I could just rig one small 12V system separate from the freezer one.
4) Be great to be able to peak shave in order to get some daily usage out of the system.
Odd to say, but good news is that my electric company has just started charging everyone a Peak Demand fee. I'll see that bill in a few days. My peak demand usage would be, I suspect, a great indicator for the size of inverter needed. Once an inverter size is determined, I can make a call on 12/24/48 voltage question.
Random garbage floating in my head:
A) Under the impression the end-state battery arrangement needs all new batteries. e.g. Its a bad idea to run banks with mixes of new and not-so-new batteries. Got that impression back in Pb battery days, but suspect it holds for LiFePO4 chemistry as well, although perhaps the BMSes could compensate? If this is true, the DIY battery built from individual cells, partly justified by being able to replace a single bad cell, is a fallacy, ?right? (since all cells should be of a similar age)?
B) Like the idea of a pass-through inverter, like the Victron Energy units, for general usage. Grid power is cheaper than solar, but its still not cheap. Seems a shame to lose efficiency via an always on inverter. Unsure, and feels a bit redundant, if I could use solar MPPT charges to augment power to a Victron based battery bank. Perhaps if the Victron could be told to only charge is the batteries were below, say, 30%, giving my default the MPPT chargers priority?
C) If I size a solar array to run the load for a few hours a day (point 1), in the winter, on cloudy days, that array is going to be wasted most of the year. So peak shaving (point 4)? or load sharing (say run off the batteries if they are > 60% charged, and only grid charge if below 30%)?
D) What am I looking for? Presuming a hybrid inverter based system? Again, thinking the inverter selection is going to drive most everything else. Recommended brands?
E) Presuming a hybrid inverter, most of which I've seen have their own MPPT charge controller, does this eliminate me being able to use the DIY Solar For U 20 amp MPPT charge controllers (presuming I end up with a 12 or 24V system)?
Brain is starting to hurt... comments/questions/clarifications/suggestions all welcome.
Thanks!
Thanks!
