Hello,
I currently run two grid-tie systems, 8kw Fronius, and a 6kw SMA. The 8k is under contract with GA Power going to a separate meter,, paying me $0.096/kw.
The 6kw is going to the house panel, a 'normal' grid-tie.
I want a new hybrid inverter to replace the SMA, and add LFP batteries. I see myself possibly expanding this system, perhaps to 10 or 12kw, so two parallel hybrid inverters.
I get confused reading the specs on these hybrid inverters. I kind of had my eye on the MPP Solar LVX6048. I am not sure it will do what I want it to.
This is what I want, so tell me if it will do it:
1. Normal grid-tie with solar charging the batteries first.
2. Battery backup of the house when the grid goes down (understand that I will have to install a 200 amp smart transfer switch).
3. Use the batteries at night or when there is little sun to obtain a net-zero condition.
Thanks in advance,
GlenB
Moultrie, GA
Thanks in advance,
GlenB
Moultrie, GA
