OffGridForGood
Catch, make or grow everything you can.
Yeah, to me this is a good mobile unit, where you have limited PV space in the first place. Camper, van-life stuff.Too bad the max PV is 60v, that really limits you to parallel only if you get used panels. Anything outside about 100-ish watts will be too high to run in series.
If they had used the same SCC as almost all their other units, it would be a LOT more useful.
I run mine on a single 440 Canadian solar PV panel - mounted vertical on a wall no-less! but my uses for this unit are not every day, so solar always (ok not Dec 2023) but nearly always has time to recharge between my uses for the mobile unit.
I could put two 440W panels in parallel and be slightly overpanelled but not needed generally for my use.
The other option would be a separate SCC just for additional PV if you wanted to add.
Anyway, I have said before, this is a small easy entry level AIO with the unique feature of the outlets built into the left side of the case, and some USB's for a phone. It is very handy for my truck and for trips to the cabin. It even runs my small well pump (120v) at the cabin so does all I need from it in a very small portable package. Will it run a home ? No. Will it do stuff a 20A recepticle would do - Yes. There are other options I just know this one.
