Carpslinger
- Dec 26, 2020
- 17
I received 12 genfang 100ah cells and they were at 2.7 to 3.1v. I put them in parallel and used a bench charger set at 3.65v and 10amps. When positive and negative leads attached, the volts went to zero and the amps to 13 and watts were zero. After one day, they volts went up to 1.6 volts on the bench charger and the amps went down to 10.7, and the watts started to climb. Not sure what was going on, I removed the bench charger and found the all my cells were all at 0.1 volts. Did I just kill these cells? What did I do wrong? Please help
