Yes new cells.Lets do some math.
I assume these are new cells. New cells generally come at ~40% SOC. 16 280Ah Cells in parallel will need .6 X 16 X 280 = 2688 Ah to fully charge. At 20A this will take 2688/20=134Hrs to fully charge. Yes, it is normal.
Keep in mind that at 3.3V 20 A is only 66W.
I typically advise folks to wire them in series with a bms and charge them till there is a cell over-voltage. This will charge in a reasonable amount of time. (52.8V x 20A = 1056W). After the BMS faults on a cell overvoltage, they can be put back in parallel to do the top balancing.
The most important tool for top balancing is patience.
Top Balancing LiFePo4 Cells using a low cost benchtop power supply.
To get the paper, click on the orange at the top of this page. This is a tutorial with detailed steps on how I top-balance my LiFePO4 Cells using a low-cost benchtop power supply. To get the tutorial, click on the orange "Download" button...diysolarforum.com
wait.. you had one that hit "max charge? you mean it hit 3.65 volts? if one out of 16 is hitting 3.65 and the rest are at 3.3, then you need to check your connections and ensure that all of your buss bars are getting good contact.Yes new cells.
I had them in series and I had one cell hit max charge while the others were still at 3.3ish.
I just wanted to confirm that this was normal gain. I wasnt sure of my math but it was the same as yours.
My first pack so being overly cautious!
Thank you for the reply
while in series configuration I had one cell go to the max voltage the bms allowed and it shut down charging. The other cells were a lot lower so i broke it down and have been top balancing in parallel for 3 days now.wait.. you had one that hit "max charge? you mean it hit 3.65 volts? if one out of 16 is hitting 3.65 and the rest are at 3.3, then you need to check your connections and ensure that all of your buss bars are getting good contact.
OK. Now it is a matter of being very patient. Set the target voltage on the Power supply before you hook it to the parallel cells and then hook it up and wait. No matter how tempted you are, DO NOT raise the voltage on the power supply.....Yes new cells.
That cell started with a higher SOC or was a 'weaker' cell. This is normal.while in series configuration I had one cell go to the max voltage the bms allowed and it shut down charging. The other cells were a lot lower so i broke it down and have been top balancing in parallel for 3 days now.
As long as the Power Supply is correctly set to the target voltage, there should be no reason to worry about over-charging the cells. At around 3.45 volts the current will start tapering off and the voltage will start going up. This will accelerate till the charge is complete.When they hit 3.45 volts, keep an eye on them!
OK in series so as a 48 volt pack. then one of the cells was either not discharged properly prior to shipping, or the others were over discharged, or you got a bum cell or two. i would put the other 15 in parallel and bring them up to about 3.45 and then reconnect the suspect cell and see if they top balance out. it could take a couple of weeks depending upon where you are in the charge process.while in series configuration I had one cell go to the max voltage the bms allowed and it shut down charging. The other cells were a lot lower so i broke it down and have been top balancing in parallel for 3 days now.
Ive had all 16 cells balancing since Sunday. Pack is reading 3.385 now so its making progress. I hope I dont have a bad cell, 100* weather coming and I need this to be working LOLOK in series so as a 48 volt pack. then one of the cells was either not discharged properly prior to shipping, or the others were over discharged, or you got a bum cell or two. i would put the other 15 in parallel and bring them up to about 3.45 and then reconnect the suspect cell and see if they top balance out. it could take a couple of weeks depending upon where you are in the charge process.
I suggest this a its not good to hold the cells at 3.65 for extended periods of time.
Patience Grasshopper. Patience.Ive had all 16 cells balancing since Sunday. Pack is reading 3.385 now so its making progress. I hope I dont have a bad cell, 100* weather coming and I need this to be working LOL
Voltage sat idle for days....Patience Grasshopper. Patience.
For how long?Then I tried individual charging of each of these cells with no movement at all.
About 4 hrs each with 20amps i was using my Icharger x8For how long?
Did you see current going in to these cells? If they were pulling current from your charger, they were still in the process of charging.About 4 hrs each with 20amps i was using my Icharger x8
Charger was on but zero movement on voltage into the cells when i checkedDid you see current going in to these cells? If they were pulling current from your charger, they were still in the process of charging.
You don't know if current was going in to the cells or not. If your power supply/charger doesn't show current, you can use the clamp on meter in your pictures.Charger was on but zero movement on voltage into the cells when i checked
Last night I charged my pack up in series till the 12 cells were in the 3.60v range. Then pulled off the bus bars to the 4 cells and charged them each. They each took about 35-40AH each till the charger stopped and my meter read 3.55v. Each took about 2hrs. No idea why they wouldn't take the charge before.You don't know if current was going in to the cells or not. If your power supply/charger doesn't show current, you can use the clamp on meter in your pictures.
I didnt notice the AH input on the charger LOL I was just looking at the Voltage LOLCharger was on but zero movement on voltage into the cells when i checked
They were taking a charge but you couldn’t see it. I know it sucks to impatiently watch them sit there for almost two weeks when it appears there’s nothing happening, but those are big hungry cells and it takes a while to fill the tank. The 4 cells in question were at a much lower SOC than the other 12 to begin with. Since you’re almost there, I’d still recommend putting all 16 in parallel and and topping them off at 3.65.No idea why they wouldn't take the charge before.
I ended up charging each of the 4 cells in question till the charger turned off. They were about 40AH away from full SOC each.They were taking a charge but you couldn’t see it. I know it sucks to impatiently watch them sit there for almost two weeks when it appears there’s nothing happening, but those are big hungry cells and it takes a while to fill the tank. The 4 cells in question were at a much lower SOC than the other 12 to begin with. Since you’re almost there, I’d still recommend putting all 16 in parallel and and topping them off at 3.65.
