I'm in the process of building an 8s2p LiFePO4 12.8 KWh DIY Powerwall and I have assembled my 230Ah prismatic cells first in parallel, and top balanced them to 3.65v with a bench power supply. After assembling in series I'm seeing good balance between cells of around .003, never over .01 while discharging at modest rates (1-15 amps). Discharging at higher rates I sometimes see delta of .01-.02 but not much more than that. I'm using a multiplus-ii to charge them individually for now at 70a, and one thing I noticed is that the delta grows larger, like .12-.13 volts at the top end as the pack approaches 28.8v. See screenshot. It always seems to be the last cells in the pack, cells 5, 7 and 8 in the screenshot below. Its not causing any problems with cell overvolt in the BMS but I'm wondering if this is problematic for other reasons.
My question is, how much of a delta is too much while charging or nearing the end of the charge cycle? What else can I check to bring them close together if the voltage is an issue?
