After having done the whole parallel top balancing thing I have come to the conclusion it is a stupid waste of time and mental energy
unless you dont have the money to
buy this. If you dont then yes, you must parallel top balance but if you can afford the $100 dont waste the time. Install the balancer, charge the pack until the BMS stops charging, stick a bench top power supply on set to 3.65v X the number of cells in series you are charging and walk away. I have done this a couple times now and it is so easy and fool proof. No taking the battery apart and putting it back together and because it is balancing at 4 amps it is super fast.
