I've searched for this specific question without luck. I have the power supply set to 3.65v and the CC is maxed out (10amps). However the voltage on the power supply is staying at 3.60 and the amps are going from 0.00 to 0.24 and anywhere in between. The cells are testing at 3.644-3.641 each (4 in parallel). So is this normal? Is it done charging or should I allow it to continue with this bouncing from 0 to .2 back to 0 for a bit more?
Video link:
Video link:
