hello,
First day of use with the TP6048. Hooked AC in and PV string. Enabled grid-tie.
Seemed to produce power back to the grid.
Did not notice, at first, the current was unbalanced. 4 amps on L1 and 8 amps on L2.
Did a sanity check by looking at my SMA inverter in grid-tie. L1 and L2 were virtually
identical current values.
I cannot explain why it is different between L1 and L2.
Second problem starts several minutes after I hook up a Lion NMC 140ah battery to the TP6048.
The unit starts charging the battery. Then I get code 60 and 61. The battery charging #14 is set to
LIC. The settings for 11, 17, 18, and 19 seem reasonable for my battery type. I checked the battery on
my BT phone app (JK BMS).
Search on the internet reveals code 60 and 61 shows an old firmware issue, BUT this is a brand new unit.
TIA
Glen K4KV
TIA
Glen K4KV
