chrisski
Solar Boondocker
- Aug 14, 2020
- 5,198
Looks like that battery runs the breakaway system in addition to the dc panel.
From the research I've done that buck converter only puts out 12.2 volts and therefore won't even come close to charging that battery.
I suggest you try powering the converter via the inverter.
I wonder how you power a 12 volt brake and brake away once you step up a fifth wheel to 24 VDC, and would like to hear form people who’ve done it.
Although I am still putting together my first PV system which is 12 volts with 600 watts of panels, I would like to someday go to 24 VDC and add more panels so I can run more watts in an inverter at less amps.
I’m stuck at the breakaway battery, and the best solution I could come up with is to let the inverter power the converter which would charge the 12 volt battery and that would operate the breakaway.
I‘m told the trailer breaks will operate off the 12 volt through the 7 pin, even without a battery, but the two times my trailer batttery died, I got an error on my brake controller, said trailer disconnected. Once the 12 volt battery was charged, which was removed and placed on an auto battery charger then put back in, the brakes work. I’m not Done looking into it. Could be my error was because there was no brake away battery, so the brake controller did not want me to drive.
I looked at the Victron step down convers and saw The 24 VDC to 12 VDC were not designe to charge batteries, and no matter what amps I got, I don’t know if it supplies enough amps to operate the breakaway.
So for the breakaway, the only thing I would feel comfortable doing with the 24 VDC I’m putting together is to keep the 12 VDC battery in charged by the inverter, but I think this could be a very wasteful way to charge the 12 volt system. When I do upgrade to 24 volts, I will spend a good long time going over some calculations and reading up.
