I have an older truck camper that I mostly dry camp with. I mostly just use electricity for lights and my CPAP, charging phones, etc... But much of a heavy load. I have a 100 watt portable panel with pwm charger that works ok. I have 2 100 watt panels I want to permanently install. Currently I have a group 27 flooded deep cycle battery, but have purchased a 100ah lithium to replace it. The camper has a Magnetek 6345 converter. Progressive dynamics makes a lithium capable replacement Pd4645V. Since I rarely use shore power, I was thinking about just leaving the old converter as I can charge the battery when home before leaving, and I don't think it will be problematic with the lithium battery other than not doing a good job of charging, but I'm not positive on this. I was thinking the cheapest, and simplest thing to do would just buy a victron smartsolar mppt 75 15 solar charger, which would give me Bluetooth monitoring and more efficient charging. The downside being that I'm limited in my upgrade path if I want to add more panels in the future.
I've also considered building a box in the camper that I can put 2 lithium batteries in. This would give me more flexibility with swapping out the converter and maybe putting in an inverter.
Is my first plan bad other than the lack of an upgrade path? Any recommendations otherwise?
