Bleedingblue
- May 12, 2020
- 564
Recently purchased 48-280AH cells. Going to run them in a 48 volt system.
I've emailed several BMS manufacturers and only a couple got back with me saying they do not make a BMS for a 48 volt system or I'd have to buy a certain battery they supply BMS for.
I've asked several people including the company I bought my cells from how I should run these cells. 3 strings of 16cells for a 280 string, or have 3 cells in parallel and run those 16 in a big battery bank for a 840AH single bank. The company I bought them from said to run 3 strings. One of the BMS manufacturers that did not make a 48 volt BMS said to run in a single 840AH bank. Another who does not make a 48 volt BMS said not to run 1 bank.
The seller said to use a Daly or Ant BMS but no specific BMS by them to use. That is like asking what vehicle do I need to buy for a trip and the person comes back with Ford or Chevy. Maybe a I need to pull a camper up in the Mountains? Maybe I need something that needs good mileage or something that seats a lot of people. No specifics whatsoever about the BMS I need to buy.
So really no clue what I should do. If a cell goes bad then the whole bank goes down.
How can a BMS handle that much power surging through it in a 840AH bank?
How in the world do you hook up 4/0 cable in a BMS?
I'd like my BMS to communicate with the hybrid charge controller with a canbus.
Like the BMS to be dependable.
I don't want to baby sit the BMS.
I will not have internet to the BMS.
How many amps will the BMS need to have if I'm running a house and shop off it?
Why does current flow through a BMS if all it needs to do is balance the cells?
May need a low temp disconnect but plan on building an insulated enclosure for it with heating mat.
What level of cell monitoring do I need? I just want it to work and for me not to worry about it.
So do I need 1 BMS or 3? Connect those 3 in parallel somehow?
In the future I may expand my battery setup even more.
I've seen videos of Will messing around with a 48 volt BMS and it had 12 guage wires. Their is no freaking way that 12 guage wires would be able to handle the amount of current that is going to be needed supplying a house and shop. I'd be ashamed to manufacturer a BMS that only had such tiny wires.
Most of the videos I've seen where people are using a BMS they are confused by them and takes them forever to try and set it up.
