Kcdaniels
- Sep 22, 2019
- 263
Ok a little background....I have a travel trailer that with the help from this forum I was able to install a 395 watt QCell with Victron 100/50 SCC... Victron 1200 VA inverter ...charging two 6volt lead acid batteries.....
On my truck topper I have two 100 watt panels that I'm going to install along with a 20amp rover scc charging one 12 volt deep cycle lead acid battery... I have a 1000 watt modified sine wave inverter that I will use...
My questions are first ...have the ability to use my 200 watts from the truck to supplement my RV batteries ...can I wire a two pin aircraft style connector to my RV batteries ? And then just plug in when needed ?
Two...I have a solar generator 1000watt that uses the same two pin aircraft connector.... Can I just connect from the 20amp rover scc to the solar generator or should that be separated from the rover 20 amp scc ?
Three...I will have a Noco Genius 5 amp connected to my truck batteries (2) at all times...this will plug in to the inverter...
Just not clear on my ability to use the 200 watts to charge the RV batteries then as needed charge the solar generator ?
Hope all that was clear as mud ...haha?
