xtal_01
Hello all!
So, I have only installed one solar system ....very simple for a client. Just a couple panels, controller and single 12 volt battery. It just ran a small pump twice a day at a remote site.
Today I got an e-mail from a friend who knew I was toying with the idea of putting in panels.
Used 12 year old panels (removed from systems to install higher eff panels) about 200 W @ 12 volt ... $20 each
Assuming they work, price looks right.
So, first question ... how good will 12 year old panels be? 25% ...50% of their rating ... 75% .. ????
Second, I know I need a controller to charge the batteries.
From there an inverter.
I have installed an inverter from an RV but that was only 120 volts.
So they make a "reasonably" priced spit phase inverter (120/240)?
Also, how do you get it to act as a true UPS? I have a generator and have to disconnect from the street supply before I plug into my generator. My little ups under my desk is smart enough to switch over without missing a beat. I know guys feed backward into the system but you must need to disconnect when the system is down as to not feed then. Some kind of smart transfer switch or ???
Thinking of this ... does the inverter need to sync with the street.
I tried to do some reading ... found a lot of stand alone systems .... most were simple and used just 12 to 120 ... but if it going to be a whole house unit it seems to get much more complicated.
Thanks .... Mike
Thanks .... Mike
