I d not quite understand the question as to what you want to know.
So I see that in the month of June you use 1.10KWHr worth of power, so what is the question on that?
The second picture it shows what you used each month, so what is the question on this one?
Where are these readouts from? How are the readings generated? It is showing AC Voltage so that means the reading is done on the output side of the inverter?
What is your system setup?
