I asked a similar question in another thread without a clear answer.
Wouldn't the inverter determine how much current it pulls?
If the inverter limits the current, the user could have 2, 3 or 4 strings, and each string would only send very little
Care to elaborate with numbers in hands ? Ohm law ? Kirchhoff's circuit laws?Except for this.
I did experiments with one panel on a ground (for easy access) - dramatically! Power dropped to 10% or less, especially low when the shadow crossed all three internal strings of the panelI don’t know how much such a shadow, if it goes across one panel reduces the output from a string with 9 405W panels.
He has offered to put in a three string inverter and do a new G99 (possibly for more export permission too) for free.
We offered to pay the difference to the bigger inverter but he wants to do it for free.
Sounds like a sensible plan to keep the optimisers on the string that has potential shadow. If you're not wifi connecting them then, in theory, you only need the optimersers on the panels that experience shadows.One last thing. Is it worth keeping the optimisers on the West roof and moving the East optimisers to it as well? Here’s the shadow detail:
In March and April, when generation amounts have risen the West side gets a 60cm wide chimney shadow from the neighbour. (Our roof is the same height as the neighbours, the apexes about ten metres apart. ) Probably August September too. May June July, that shadow has moved round before it creeps up to the solar panels - and misses them.
There are no other shadows.
Never a numpty questionSorry for such a numpty question.
Bit off topic, but to answer that (as I triggered the query in the first place).... it depends on how the inverter's MPPT algorithm works.I asked a similar question in another thread without a clear answer.
If the inverter limits the current, the user could have 2, 3 or 4 strings, and each string would only send very little current?
YesI asked a similar question in another thread without a clear answer.
When solar panels are wired in series, they become one single large panel.Care to elaborate with numbers in hands ? Ohm law ? Kirchhoff's circuit laws?
I would keep them.My question is about optimising the west strings which will se a chimney shadow some of the year…but no other shadows .
Rather than go into those, Tigo’s website doesn’t recommend putting East and West panels on the same string. What actually happens is that power generation is restricted across the entire string even in full sun at the start and end of a day.Care to elaborate with numbers in hands ? Ohm law ? Kirchhoff's circuit laws?
Thanks. I’m trying to cost how much energy I’d lose across 25 years against the cost of optimisers. It might be they save me £5 a year or £100 a year….I don’t know!I would keep them.
Optimizers help during temporary shadowing. (Moving shadows)
I don't know either. I've never needed them.Thanks. I’m trying to cost how much energy I’d lose across 25 years against the cost of optimisers. It might be they save me £5 a year or £100 a year….I don’t know!
Not that what we got - the point is using panels with own optimizers.When solar panels are wired in series, they become one single large panel.
I'm not sure what you are saying.Not that what we got
The point is that the "instaler" tried to use optimizers to correct their design flaw.the point is using panels with own optimizers.
For me it would be 'worth' it for not seeing a "dip" in production when the shadow goes across the panels, irrespective of any financial savings... but YMMV.Is it worth keeping the optimisers on the West roof...
I’m like that too…so is the installer at heart. Had to look up YMMV. LOL!You asked...
Well. Not everyone has acres of land in own possession!The point is that the "instaler" tried to use optimizers to correct their design flaw.
3 directions, 3 strings.Well. Not everyone has acres of land in own possession!
My place has available pitched roofs with 17 degrees of inclination in three directions: E, S and W. Only.
No way to run all my 19 panels without 18 optimizers ! Period.
Yes, I have a few, include VERY tall tree at W side, a chimney is there, tall structure holding my two tanks with cold/hot water, water solar heating panels, a couple of 12' sat dishes. Plus, part of walls at an edge between roofs making shadesIf you have shading issues, then I would understand optimizers.
It would force me to run a lot of DC cables to the SE3000 inverter.3 directions, 3 strings.
Wow, that's a lot to deal with.Yes, I have a few, include VERY tall tree at W side, a chimney is there, tall structure holding my two tanks with cold/hot water, water solar heating panels, a couple of 12' sat dishes. Plus, part of walls at an edge between roofs making shades![]()
A single string broken up across 3 different directions is never optimal.It would force me to run a lot of DC cables to the SE3000 inverter.
One string with OPs is optimal setup. I posted a plot of one day generation - see above.
