Each panelIs that means each panel have own OP or each string ?
With all due respect, you have just jumped in and hijacked someone else's thread; suddenly making it difficult for me to answer the OP's questions.I'm curious about your technical explanation of my setup (done by local company): one string with 18 panels, each equipped with own optimizer and connected to 1ph inverter (SolarEdge's OPs and the inverter).
Thanks
Installed by a contractor.
PV1, 12 West
PV2, 6 West 6 East
PV1 is superb
PV2 doesn’t ’wake up’ in bright sun until around 9am, then jumps from 20W to around 300W then later, say 10:30 is fine until around 16:00. This time of year.
In bright cloud, PV2 works better than bright sun before around 9am
Okay thanksAs @timselectric has said, this installation has been done incorrectly. You can't successfully mix east and west on one string.
The behaviour you describe is as expected for that configuration.
Get the installer's back to resolve it.
OK, I'll stick with OP topic and ask about technical details of the statement. Counting each panel in the [split] string have own OP, eg isolating from each other ?You can't successfully mix east and west on one string.
YesOK, I'll stick with OP topic and ask about technical details of the statement. Counting each panel in the [split] string have own OP, eg isolating from each other ?
A bit more detail. The idea being that when the sun is rising on the East, the West panels in the shade of the roof do not limit the generation of-the East panels which are in bright sun with no shadows. So in the afternoon, the opposite. But what happens is that in bright sun (which this time of the year the East panels get from 5am) neither the west 6 or the east 6 on the string do much at all (around 20W total) Until the sun is much higher around 9am.OK, I'll stick with OP topic and ask about technical details of the statement. Counting each panel in the [split] string have own OP, eg isolating from each other ?
Sorry, my poor use of words.Optimizers don't isolate panels in a string. They just try to keep them from pulling the rest down as much.
They Optimize each panel to minimize the losses as much as they can.
Was it partially cloudy this am?Today at 08:00 was a welcome exception. So I don’t think it’s a design fault but an intermittent issue
I’m afraid I don’t know the answers to your last two paragraphs. I’m just an old bald homeowner!Was it partially cloudy this am?
I have and E-W configuration (albeit correctly on 2 strings). When it is cloudy both strings will generate the same amount. If sunny and clear skies, the sun-facing string will generate more power.
AFAIAA, optimisers are designed to resolve partial shading issues, not fix a poor design.
What inverter do you have and what is Voc of your panels? Just trying to think of other configuration options.
No.I’ll check that, thanks. But they said they had 3 east and 9 west on one string.
Making max output of a panel's power when its voltage and current are variable (include shading) is main task of OP, IMO.AFAIAA, optimisers are designed to resolve partial shading issues, not fix a poor design.
I’ll check!No.
You misunderstood.
Thanks! I’d love to have it. I know that about 8 years ago it was poor for inclinations above 15 degrees…but optimiser tech probably improved since then.Making max output of a panel's power when its voltage and current are variable (include shading) is main task of OP, IMO.
I'm still waiting for definitive technical note about poor design E-W positioning panels in one string, when OPs are there.
Thanks. I will.Not sure what make of optimisers you have have, but Tigo is one of the most commonly used in the UK...
Hence, from Tigo themselves, they state... "If your PV modules are wired in series, and your design includes a hard angle (some facing east, and some facing west), the early morning and late afternoons may see a short period where there is a complete drop-off of production for the heavily shaded PV-Modules. This is a normal function of Optimization.
Tigo Optimization allows the strongest modules to produce at their best, through impedance matching. If there is light shading, the units will optimize for more current. However, if modules are heavily shaded, their output will be reduced so that the lack of current will now no longer affect the entire string's production."
See more info here.. https://support.tigoenergy.com/hc/e...em-for-different-tilts-angles-and-orientation
Their explanations in that article concur with the performance you have observed.
IMHO Optimisers should not have been used to try and get panels that are facing in 180 degree different directions to work on one MPPT string. The inverter will not be able to work properly in that manner. Hence my recommendation in post #28, "Get the installer's back to resolve it."
On closer reading, that’s not what is happening though…..Not sure what make of optimisers you have have, but Tigo is one of the most commonly used in the UK...
Thanks for your thoughts! I’ll talk to them next week.see https://en.wikipedia.org/wiki/Maximum_power_point_tracking
Essentially a technique inverters use for extracting the maximum power for any given light condition by adjusting current drawn from the panels. But this relies on all panels in the string having the same maximum voltage/current point as each other, which won't be the case when they are facing opposite sides of the earth.
What can the installers do? Thoughts that spring to mind include:-
a) Reorganise the configuration to have two west facing strings of 9 panels each on one MPPT and the remaining 6 east-facing on the other MPPT input? But that will depend on max voltage / current supported by your inverter.
b) Deploy an additional inverter so you can configure your system with 3 strings
c) Give you a refund for their incompetence and put up with the loss of generation
When in shade, (before around 08:30 on the westward side) the west side are generating very little if anything (as in the Tigo article)….and the ones in direct sun are also generating very little if anything (not like the Tigo article)! The whole string is only producing 20W.
In post#26 @BaldDave replied: each of panel in the string have own optimizer."Tigo recommends dividing the string into two separate strings in series going into separate MPPTs"
Yes, I understand that... how does that relate to their recommendations though?In post#26 @BaldDave replied: each of panel in the string have own optimizer.
That's seems OK for me , if you have one optimizer/MPPT for whole string .Yes, I understand that... how does that relate to their recommendations though?
