Welcome to the forum.
That looks a lot like yet another rebranded AIMS/Sigineer unit, and NEW Sigineer units can be had for similar pricing:
They don't list the 2kW version, but they have the 1.5kW version for $387.50 and the 3kW version for $540.
$1600 is grossly inflated. For that price, there are notably superior high-end models of other brands.
The main downside to these units is their efficiency. They have lower peak efficiency than high end low frequency inverters and LOW/mid-range high frequency units.
Another consideration is that inverters have idle draw, i.e., they consume power just by making 120VAC available even if nothing is using it. Those units tend to be higher. It's not listed, but I expect it has a 25W idle consumption. That's 600Wh/day. Assuming 12.8V/280Ah battery, that's 17% of your battery capacity - just by being on. This is an issue on all inverters, and some have low-power mode, but if anything is drawing power, the power-save mode is disable. This feature is more often annoying than functional.
2kW with 6kW potential surge is great for starting motors, but if you don't need that, you're paying for it in other ways (lower efficiency and higher idle consumption).
The high frequency inverters Will lists may be better choices for you and cheaper:
Building a vehicle mounted solar power system? Let me help.
www.mobile-solarpower.com
