Hi I've been considering this for some time now, I would really appreciate the forum members thoughts on this proposal, all feedback is welcome. Rough drawings below. Thanks in advance..
Each end of the season (Mediterranean) not generating enough power and barely generating enough during high season. More power would enhance living comfort audio/visual use, fans etc. Main draw is refrigerator, Power demand for charging phones/laptops etc is increasing,
Present setup =
160w solar, Rutland 913 wind generator, dual pwm solar and wind controller, 60amp alternator and split charge relay, smart battery monitor, 75ah lead acid engine start battery,
230ah lead acid service battery charges to about 80% then goes to float charge and overnight will drop to around 60% this is using only 20% capacity = 46ah out of only 69ah max available ie discharge to 50%
Proposed setup =
260w solar, CTEK D250SE Dual Input DC-DC Charger & MPPT Solar Controller, Rutland 913 wind generator, dual pwm solar and wind controller (now used solely for wind to charge start battery), 60amp alternator, smart battery monitor (now solely for engine battery), Victron Battery Protect BP100, 75ah lead acid engine start battery,
190ah lithium battery with Bluetooth monitor app, (conservative charge regime) will charge to 90% and discharge down to 20% (70%) = 133ah available
Benefits of proposed upgrade
Moving to a MPPT charger with 5 stage charging from either solar or alternator to charge Lead Acid start battery and LifePO4 service battery (improved battery charging). Utilise more solar energy generated, at present some is being wasted and dumped when battery reaches float stage.
Upgrade can be done in stages, to include the new CETEK solar charger will be a minimal wiring change, will allow future use of increased solar capacity (current solar charger max is 160w), and provide pathway for lithium install. Current Lead Acid service battery 4yrs old so will need replacing soon (Replacement Lead Acid Around £250-300) Lithium option Approx. £600. (Aluminium cased raw cells 190ah)
Features of the CTEK D250SE Dual Input DC-DC Charger & MPPT Solar Controller
LifePO4 Battery protection
High voltage - max charging 14.2V floating at 13.3V so will not overcharge (LifePO4 setting)
Low voltage / battery drain – Victron battery protect will cut load before depleting the battery and before reaching BMS low failsafe settings
Present setup
Proposed Setup
Present setup =
Proposed setup =
- Can be used with Lead Acid and Lithium
- max output 20A so will not overstress 60A alternator (improved 5 Stage charging)
- small size, IP65 (splash proof important for a marine environment)
- Trickle charging of the starter battery from a solar panel
- Can be charged with current 230v charger (through starter battery)
Present setup
Proposed Setup
