You'll likely see a 10-15% improvement in total daily energy harvest.
MPPT tend to be larger due to more and complex circuitry. Fitting to the hole of a 30A PWM is probably impossible, and you likely don't even want to try. MPPT typically have a heat sink and shouldn't be mounted recessed.
Check to see if a Victron MPPT 100/30 works for you.
