SomeSparrowSings
Hi. I'm brand spanking new here. I have two 100 W flexible panels on top of my mini-campervan, which I've used with a Jackery 500 (530 Wh) for a couple years now. Finally decided that I need more power, and just bought a Bluetti AC180 (1152 Wh). Meanwhile I also have a Renogy 100w portable panel I've used when I wanna park my van in the shade but get power via this panel on an extension cord. I stumbled upon an 8 mm splitter and finally decided to chance it and plug both the Renogy and the two parallel'd panels into it and feed that into the Bluetti. The result is that I basically doubled my wattage intake, which was awesome. Seems to work just fine.
The problem is that I am really not very satisfied with the Bluetti, due to its internal power consumption of 15w, which really sucks a lot of power on a constant basis, and generally doesn't jive well with my light loads lifestyle. So now I'm looking at a Grecell 1000w power station. But it accepts a lower amp limit, so I am worried about possibly blowing out the solar controller. While I've certainly read a fair bit about solar, and amps, volts, and watts etc, some of it still just goes over my head. Below are the specs for these different solar instruments of mind I've just mentioned. Based on this, can someone tell me whether I've been playing with fire with the Bluetti, or if it's fine and I'd be fine too with using these 3 panels together with the Grecell unit? I've got a very short window of time in which I can essentially return the Bluetti and get the Grecell. Any input would be greatly appreciated.
Topsolar panels
100W 24V/12V Monocrystalline Bendable, 100 watt / 12 volt = 8.33 Amp output. Voc of the TopSolar panel is a bit over 22 volts.
REnogy 100W PORTABLE SOLAR PANELS
Max Power at STC: 100 W
Open Circuit Voltage: 23.40V
Short Circuit Current: 5.26A
Optimum Operating Voltage: 20.16V
Optimum Operating Current: 4.96A
Cell Efficiency: >23.5%
Bluetti 180 power station,
12V-60V, Input current 10A 500w max
Grecell T1000 power station
Voltage of solar panels allowed is 12-26V, 8A 155W (Max). So for our 1000w power station, 60W/80W/100W/120W/150W/200W solar panel is supported
Topsolar panels
