Sunny Day
I have a run of about 25m of copper water pipe which draws from my hot water tank and has a loop back (U connection) at the destination end (close to the taps in my house), also a circulation pump which will drive water through this circuit and, if the water returns warmer than it left the tank, the heat will accumulate into my hot water tank.
What I am pondering is the feasibility of using nickel chrome wire wrapped around the outside of the pipe as a resistive heating element to dump heat energy from my PV panels into the water, once my batteries are fully charged each afternoon. If the circulating pump runs at the same time and if the heat can be delivered to the outside of the pipes at a suitable temperature (below 100C!), I would imagine this might work and has the benefit of avoiding breaking into the pipework and doing any plumbing (which I suck at!)
But.. I have no idea how to calculate what length or gauge of NiChrome to use, how many turns around the pipework, what kind of insulator to put on the copper pipe first (so the NiChrome doesn’t short circuit), or in fact if the idea has any merit or will be a big waste of time and money
The cabling from my PV panels arrives in the vicinity of this loop back connection, so I could wrap both the send and receive leg of the pipework and heat the water twice before it makes it back to the accumulating tank. I have around 2-3m of exposed pipework inside the house close to my PV system available for NiChrome to ne wrapped around.
2 of my PV circuits are from 3x 100W panels in parallel, with an open circuit voltage of 18-20V and short circuit current of around 18A once disconnected from my batteries. The other two circuits are 2S3P arrays with an open circuit voltage of around 54-58V and short circuit current of about 18A.
I’m guessing there won’t be many people using NiChrome for PV diversion, but is there anyone good with sums who fancies having a go figuring out what arrangement of wire gauge, turns and covered pipe length might work to get the water warmed enough but not boiled before it goes back to the tank? The flow rate of the circulating pump is “up to 1.5 cubic meter per hour” according to the spec sheet.
ps… I mentioned NiChrome as I’m familiar with it being a resistive heating product , but maybe there are off the shelf “heating mat” type products in a long thin form factor which could just be wrapped around the pipes? Let me know if you know or anything suitable ?
