D
Deleted member 3614
Guest
Long shot,
Is it possible to run a uv water treatment lamp direct from the batteries? my motorhome has a silly UK safety law where starting the engine will cut all power in the van.
UV lamps needs to be run constantly, turning them on and off will shorten their life.
I have a 1500 inverter so could use that left on which isn't affected by the power cut, can use the inverter but it uses a bit more power.
UV lamp is 25 watt on a 12-volt system.
