Russ
- Oct 1, 2019
- 184
I recently purchased 2 Valence 138 ah batteries with 300 or less cycles that were used in electric vehicles. I have both in parallel and use a 4 amp battery tender connected.
When charged they go to either 14.5 or 14.7 and then slowly drop to 13.38 which I have verified correct. Green lights are flashing. An example of their performance in about 3 hours they dropped to 10.7 volts and the transfer switch went to grid as it should. I did not have 3 amps or over 300 watts load on the batteries and the amps and watts would drop below this many times. The batteries were at 12.5 or 12.7 and dropped to 10.7 that fast as measured at the transfer switch and Renogy Adventurer battery charge set to LI . I have a Pure Sine Wave 3000-6000.
All cables are over sized. The batteries are now charging back up quickly. Have done this with BMS cables attached and detached.
Any Ideas
Any Ideas
