As often happens, my small project has turned into a much larger one. I originally was going to build a simple UPS for my server rack which runs fairly constant 300-370 watts. Then I thought why not replace several other UPS in the house - main desktop (2-400watt) and give some additional headroom to run an extension cord to the main fridge if power were out for an extended time. This means no more small victron and I now have the 24/3000/70 on order.
I noticed the 50A shore input- previously was going to use the existing 12ga romex but now that is no longer an option. Now that I have created a monster, I am wanting to get a bit of input to see if my thinking is the best way to do this
Victron supplied by 8 304Ah EVE cells in series
Place victron in utility closet next to main panel (instead of near server rack)
Install a new sub panel next to main panel. Pull out breaker/wiring that feeds the server rack and refrigerator and move to this new sub panel
New sub panel fed with the 50A line from the Victron
The 50A is way overkill for just these two circuits and I will probably add in another circuit or two - probably the tankless water heater as no power= no hot water. It's only power requirement is the inducer/exhaust fan which is only a few dozen watts. Still a lot of extra room.
What type of sub panel would be most suitable for this application? Does the 50A victron supply to the new panel require a breaker in between (similar to the main feeders from utility pole)? I have seen a few small, 5ish breaker panels that I assume are a very trimmed down version of a typical sub panel but with only one 120V feeder. I know the more traditional sub panel I could just bond the two lugs but I assume there's a cheaper option here. Obviously K.I.S.S. has left the building
What would you do with the second 32A victron output? I know this cannot be thrown into the new sub panel.
No solar input currently but one day that may be an option. If we ever had an extended outage, I would recharge the batteries as needed from a gas generator but in our 5 years of living here that would have only been needed once so I wouldn't want to consider this a big need in the wiring.
The other option I believe I have seen you can limit the input current to the Victron. I could keep this at 15A but that may just be a waste of a larger Victron unit?
