I am wanting to add a Smart Sense to compliment my Victron components.
The literature purports to further optimize charging by adjusting voltages with regard to temperature of the batteries.
I am currently monitoring voltage for both the starter battery and the house bank at the BMV shunt with the included leads. If/when using the optional accessory temperature sensor it displaces the voltage monitoring leads. I want to keep the existing dual bank voltage monitoring - and with a Battery Sense I am hoping to add the temp monitoring. The Battery Sense also adds another layer of cold temp charge protection, as I understand it will invoke a cutoff at the MPPT(s).
I mention the optional accessory above to point out it measures temperature with a thermistor. But regarding the Smart Sense the Victron literature uses language such as, “You can mount the dongle itself directly on the battery.” Does not say “must” mount. Furthermore, It does not say where specifically on the battery it can or should be mounted.
- Does anyone know exactly how the temperature is measured by the Smart Sense module? Surely it can’t be reading case temp through the adhesive backing? Is it measuring ambient?
- Why can’t the VE network use the data provided by the optional accessory temp thermistor (via the BMV Shunt) to perform the same optimization function as through the Smart Sense? Or is this already a function and I missed the plot?
