Danielelongo
- Jun 1, 2020
- 3
Hi everyone,
I just finished installing a 330-watt solar panel combined with a Victron 100 | 30 MPPT charge controller, a BMV-700 battery monitor, and two 145 Ah AGM batteries on my motorhome and need some help/clarification.
To start with, I'm quite satisfied with the system but quite confused with the battery monitor readings.
For instance, after a long day using DC appliances and charging laptops, I went to bed with the controller reading a 76% capacity left in the battery bank. Now this morning at 7 am I it checked it again and it still indicated a 76% capacity with a draw on the battery of around -1 amp. The sun was weak, we were mostly in the shadow, and we were drawing a -1 amp. To my surprise an hour later the battery monitor was reading full battery at 100%.
Here is my question how is that possible? I'm worried that the batteries are and may get damaged because the battery controller would not top them up?!
Another thing I noticed is that although the monitor indicates 100%, the voltage can vary quite a bit. I thought that voltage and battery percentage capacity would be linked?
Lastly, not sure why the monitor is not displaying the Ah, and the h, any idea?
Your help and clarification are very welcome. I would hate damaging the batteries.
Thanks
Daniel
Thanks
Daniel
