0e003402d9ed253c88a603
Hi all, I’m building a mobile power station centered around a 200Ah LiFEPO4 battery. At some point there will be a solar panel and charger incorporate, in the meantime I’ll charge it on the mains power (using home solar). Is there any issue with wiring the Victron 15A charger to a spot on the Blue Sea 6-way distribution block? Yes, I could put the charger directly to the terminals but for my lower power side (<30A) I wanted to wire everything to the distribution block. Given the charger is 15A, the distribution block is 30A per channel and there there is a 100A MRBF on the battery to the distribution block.
Thoughts?
Thoughts?
