IdleHandsICantStand
I have a generator that has a 30 amp RV outlet. The battery charger has a fuse of 40 amps, rated for 30 amps. The only way I can find to run the generator with 30 amp is to make my own extension cord and or change the plug used on the charger itself. I have no problem with doing so but I am wondering if the wire used in the battery charger can actually handle 30 amps. The plug itself is only rated for 15 amps. I don't see how I can safely do it? Change the lead wire inside of the battery charger? Am I missing something here?
Plug
Battery Charger
Plug
CHING CHENG WIRE MATERIAL CO., LTD.
www.chingcheng.com.tw
Battery Charger
