I have a question on how the multiplus and smartsolar systems integrate into a system.
1. How do each of these detect high/low voltage conditions in light of the fact that the other device might be putting a charge on the system? For instance if smartsolar is charging the battery how does multiplus know to not attempt to charge. Is this automatic or does it require manual intervention?
2. If using a bms (diy battery) that can control external devices like chargery or electrodacus, how to shutoff both of these devices in case of overcharge?
3. On undervoltage, again using a bms like chargery that controls the external equipment, what happens for the standard 12 volt system in an RV? From what I can see that is not routed through the multiplus so I guess it just stays live (but inverter shuts off), or do people normally install a relay on the 12v in addition to signally the multiplus?
4. I think the smartsolar needs a batterysense (sp?) device in order to learn the battery voltage and temperature,. Can one of these support both the smartsolar and multiplus, or is best practice to use 2?
I've looked around a bit but not seen schematics for this kind of setup that help understand, thanks in advance for any pointers.
Bob
Bob
