Issue: fluctuating charging voltage from multiplus 3k 12v - swings from low around 13.5 up to over 16 volts as reported on the Victron Connect app. This is a new system (latest firmware on all components), I have the programming dongle and have set the charging parameters as per instructions from LiTime (400ah batt). We can see the 16v flash by in the Victron Connect app on the programming PC and from the shunt readout on my phone, but it does not show in the Trends report or the History report on the Smart Shunt so far as I can see.
Has anyone seen this before? I had assumed the charging voltage would be relatively steady.
System:
Litime 400ah battery fully charged with Litime charger before use
Multiplus 3k 12v with bluetooth dongle
also
SmartSolar MPPT 100/50, not yet hooked up to any solar
Lynx Distributor
System:
also
Lynx Distributor
