I am trying to figure out how to use the Victron 12/24-220 SBP with my Giandel 2000/4000 PSW inverter that runs my off-grid shop. Before the flames, I know it says, "Do not hook directly to a device with capacitors, such as an inverter." That said, I saw in one of Will's videos him doing this very thing, so I tried it.
If the capacitors are already charged, no problem, except the SBP won't supply enough power (amps? voltage?, I see the voltage readout on the inverter drop to 19v when I switch on the shopvac.) to run a large motor like a vacuum or bench grinder. These type of draws are fine when the inverter is wired direct to the battery bank (4 × 235ah Vmax 6v, @ 24v), protected by a 150a fuse. The SBP 220 is rated at 220a continuous and 600a surge.
My guess is high draws through the SBP are causing it to momentarily drop below LBC setting. My reasoning is that if the capacitors on the inverter are not charged prior to bringing the SBP into the loop, the inverter will try to start then beep and show lo bat, but, if I leave it on within 10-15 seconds it will fire up momentarily before beeping again and showing lo Bat. This will continue for a continue with the lo bat intervals getting shorter and shorter until the inverter is happy with the supplied power.... presumably when the capacitors have fully charged.
The inverter does have an on/off remote port but I'm not smart enough to know how to use the SBP to turn the swing and on. The switch obviously can't handle the 24v so some kind of relay would have to be involved.
Any help appreciated, specific on exactly how to do this... HOW YOU ACCOMPLISHED this would be GREATLY APPRECIATED!
THANKS!
THANKS!
