In a proper system, you should have a disconnect switch between the battery bank and the inverter. You should be able to connect all the cables with no sparks while the disconnect switch is open (turned off).
Then connect your resistor across the disconnect switch. 30 ohms seems a little high. On a 48 volt system, it will start at a little over an amp and then the current will drop off as the caps charge. That might be enough. I use an 8 ohm resistor, it gives over 4 amps. That is enough to actually turn on the inverter control panel. When I see that light up, I know I can close the disconnect switch safely.
Another good one is using a light bulb. 120 volt bulbs are a bit high on resistance, but do work. Car headlight bulbs are great for 12 volt system, pulling about 5 amps. For a 48 volt system, you will need about 3 in series to keep them from burning out. The fun thing about the bulbs is they will light up and dim out when the caps are charged up. Good visual indicator. I was going to wire one in with a button, but it has been over 2 years since my battery was powered off. It's not something you need to do very often.
