No, it doesn't say it's charging, the amps and watts are quite correct for discharge.If it's discharging and says it's charging you have it hooked up physically backwards.
So, a few days is how long it takes :·)It will take a few full cycles from full charge to full discharge for the monitor to really give good data, use it for a few days,
But it does say it's charging...No, it doesn't say it's charging, the amps and watts are quite correct for discharge.
@Don B. Cilly he is correct here, I have one so I'm familiar with it, so it is showing charge and if you are pulling a discharge you need to switch your cables around. When it shows discharge it will show negative -xx.xxvBut it does say it's charging...
The amount it's discharging would of course be correct, the problem is it's going the wrong direction. The shunt thinks your discharge current is going into the battery.
If you are discharging it should show a negative wattage value.
This is also why it's showing 0.0ah consumed.
Can you post a photo of your wiring?
My 500a smartshunt immediately showed correct discharging and started counting consumed amp hours within the time it took me to pull my phone out of my pocket and connect to it.
I hadn't even started configuring it for battery capacity yet at that point.
Hopefully OP comes back.@Don B. Cilly he is correct here and I have one so it is showing charge in so if you are pulling a discharge you need to switch your cables around.
Do you have a solar charge controller??I disconnected the panels. I don't really want the battery to go over 27.2 anyway, do I?
