E. Bryan Hoover
- Aug 7, 2020
- 17
This is a suggestion FOR A VIDEO to show using Super Capacitors to start a Refrigerator.
My refrigerator is an inverter start so I don't need to worry about starting it or it using much energy.This is a suggestion FOR A VIDEO to show using Super Capacitors to start a Refrigerator.
I would like to see a video about the advantages of inverter start refrigerators, Air Conditioners and anything else that has a soft start to be easier on off grid or RV systems.
GE made by HajerWhich refrigerator did you buy that is based on inverter technology (Make and Model)?
I don't know what other brands use inverters.What are the alternative refrigerators (make and module) that use invertor technology?
Is it that your invertor refrigerator DOES NOT START or is it that your invertor refrigerator STARTS LESS OFTEN?
It was on sale a year and a half ago at Home Depot. I think around $1100How much did you invertor refrigerator cost?
When did you buy your invertor technology refrigerator?
What size is the refrigerator portion of your refrigerator?
What size is the freezer portion of your refrigerator?
I don't know other than how the compressor is run how air circulation would be any different with a non inverter refrigerator. Care to enlighten us. The Inverter start AC units i have looked at are split units and I also don't know why that would affect the wall unit which also has a variable speed fan.I am familiar with HVAC invertor technology - not only was the equipment much more expensive BUT the distribution of air was critical in an invertor HVAC system AND I suspect that also causes issues with refrigerators.
Very interesting. I suppose if you tried a simple single-to-three phase conversion you wouldn't have frequency control, hence the rectification to DC, then inversion to three-phase AC. Very cool (and very pun-tastic).The inverter converts single phase electric to DC that runs the variable frequency output three phase inverter. The variable frequency allows the compressor motor speed to be continuously varied based on refrigerent flow need.
GE made by Hajer
I never hear it start but maybe is runs so slow that it never stops.
I don't know the cubic feet. It fit in the hole in the wall just right.
It was a French door with a roll out bottom freezer. i know the freezer can hold over 75lbs of frozen Salmon I brought back from Alaska last year.
Invertor technology varies the speed at which BOTH the compressor AND the fan that puts a load on the compressor (the fan on the inside of the fridge) - the speed at which both runs must be perfectly matched.
In the case of a HVAC system the duct work must be both designed AND built perfectly so that the balance of air between rooms remains constant REGARDLESS OF THE SPEED. This requires an old school master craftsman (which we had access to - but - why - is beyond the scope of this discussion).
The reason an advantage to an invertor HVAC system existed was that the invertor HVAC system rarely shuts off it just slows way down and matches Speed TO Load.
The problems with HVAC SYSTEMS were three: 1). Three times the cost of equipment, 2. Very poor performance, OR, 3. The high cost of having a Master Craftsman Design and Build the duct work.
I'll remember to only buy an inverter fridge where the manufacturer specifically states their compressor and internal fan speed have been taken into consideration as part of the normal design and testing process.
Oh wait, that'll be all of them.
Basically it has a 3 phase synchronous motor drive controller built into. These ramp up motors by applying lower voltage at lower frequency and gradually increasing both as the motor starts up. Synchronous motor speed is controlled by frequency, not voltage. Very cool (joke intended) technology.Very interesting. I suppose if you tried a simple single-to-three phase conversion you wouldn't have frequency control, hence the rectification to DC, then inversion to three-phase AC. Very cool (and very pun-tastic).
And we still use it since nothing is better.And the three phase motor technology was invented by Nicola Tesla over a hundred years ago.
I watched "The Current War" recently, very interesting. Not sure how much was based on fact, but interesting nonetheless.Probably the single most important invention of the 19th century.
