Tony S
There HAS TO BE a WAY!
I would like to come up with a way to be able to charge the 200MAX through the PV port using charging system 1 & 2 listed below.
I would prefer to use the PV Charging port on the right and switch between the 2 ways and times I want to charge. UNLESS - I could do both at the same time and ONLY drop the ALTERNATOR charging when the engine is not running.
WHY - I would rather not have to use the charging brick and have another fan making noise inside my sleeper box.
Ways I want to charge:
1. Use the 2nd Alternator ALREADY on my Rig, as a designated charging source, on my rig to maybe a DC to DC 12v to 48v Step-up Converter into the PV Charing port while driving. (I'm open to other ideas - as I don't know what all is available to make something like this work.)
2. Minimum of one 220W Bi-facial panel (Maximum of 2 panels or 440W) into the PV Charging Port - use ONLY when Parked.
I have no clue what components would be the better choice and way to make it all work.
Or if there is a way to make the switching between the two CHARGING systems "Automatic".
(I thought maybe I could have a relay with a default to the Panel circuit, for charging when the engine is not running. The relay would activate and change the switch over to the Alternator charging system when the engine is running and default to the panels when not running. That way I could use the same port on the 200MAX and push a higher charge into it and not have to manual plug and unplug the 2 different connectors.)
Sounds good in my head. But is there any way to something like this work and how safe would it be?
NOTE: I'm NOT charging 2 batteries and I'm ONLY using ONE PORT on the 200MAX.
Thanks ahead of time for your help and input.
Sincerely, Tony
My Rig that I plan to put one if not two 220W Bi-Facial panels on.
NOTE: If I use the PV setting I can push more into the unit when charging and I would prefer NOT to use the brick for the port on the right.
Sincerely, Tony
