Doggydogworld
- Aug 29, 2022
- 366
That's the right way to look at it. If you use the house 2-3 days for 20 weekends a year that's ~50 days. A "50 day" solar/battery system costs the same as a 365 day system, but propane cost is 85% less. The normal "payoff math" some are using here does not apply.This is for a summer, second home used almost exclusively on weekends. Figure 20-30 loads of laundry a year. My concern is more running out of battery capacity than the cost of propane, which I can't see being that much when only being used for the dryer, stove, and possibly hot water heater. Maybe I'm mistaken?
Before buying a bunch of panels, batteries and inverters you need to know how much air conditioning you need. Pros use "Manual J" calculations for this. I just looked up Block Island weather as an example (may not match your island). A well built house doesn't really need A/C at all there, but it could increase comfort by knocking down the humidity. Sealing against leaks and running the A/C only in daylight hours could work very well. You might need more panels, but they're cheap.
Other options -- run a larger mini-split unit in the main part of the house during the day then turn it off and run little window units or mini-splits off battery in the bedrooms at night. Or put A/C everywhere and run it off panels in the day and generator a few hours after sunset. Depending on model, location and shed design a generator could be quieter than the A/C units. Propane a few hours a day for ~30 days (don't need A/C in April or October) could be a lot less expensive than 16 more Battleborns. And batteries could still run low if it's really cloudy and humid.
