There are normally two different wattage standards that most panel companies publish. The STC, which is the standard test conditions of illuminance at 1000W/meter squared at 25 degrees C,
and the NOCT rating for nominal operating cell temperature, which is 800W/meter squared at 46 degrees C.
Manufacturers understand that panels almost never put out their "rated output", which is because you can't guarranty the sun is putting out exactly 1000W/m2 during the day, and also that power output (voltage) goes down as the panels sit in the hot sun all day. So, the NOCT is more of a "worst case" rating that people will always see the panels perform better then.
So, the different values may represent the difference between the STC and NOCT ratings?
