tigerwillow1
- Sep 20, 2021
- 194
One of the advantages I imagined with LiFePO4 batteries was that if one cell died it could be replaced instead of pitching the whole battery out. I see that pretty much all of the preassembled batteries use welded busbars, which I figure pretty much eliminated the possibility of replacing a cell. I can see the welding as a big advantage in a mobile application, not so much in a stationary application like residential backup power. Welding the busbars obviously reduces the chance of a failure, but is giving up the capability to replace a cell worth that small reliability improvement? I see it as comparing the risk of a loose busbar connection in a stationary battery against the risk of a cell going bad. Is there an obvious answer to this?
Driving the question is four of my 12 volt AGM batteries, each with one bad cell.
