I have 4 x 300Ah CATL LiFePo4 in series on a boat charging from 300w solar. 2 x victron smartsolar regulators & a victron smartshunt. regulators read to voltage from the smartshunt & are set to bulk - 13.9v (3.475v per cell) then 'float' - 13.37v (3.3425v per cell). No absorption time.
A raspberry pi reads & logs data from the smartshunt.
This seems to work fine, but I don't believe the smartshunt SOC, it was set months ago & good chance it has drifted. So what SOC do you think the cells have got to when voltage gets up to 13.9v? Shunt says about 60%.
This shows it quite well with the regulators going from bulk to float at just under 14v (3.5v per cell)
SOC graph shows just under 58%. Not sure I believe that..??
'Float' seems to work OK, just keeps on top of house loads, you can see the fridge cycling quite clearly
So what do you think the SOC might be when it gets into the upper knee? Or any other comments? Actually not too bothered what it is, seems well within safe limits & there's plenty capacity so never gets discharged too much. It works! ?
What was interesting was absorption, tried 1h absorption but nothing much went in to the battery after leaving bulk keeping voltage up so now go straight to 'float' (not really the same as lead acid float)
Thanks ?
Edit: Just set absorption voltage to 14.2v (3.55v) just for today, thinking of resetting capacity to 100% when it gets there & live with that. Comments? ?
Thanks ?
