I have an EG4 6500EX inverter connected to 3 EG4 48V LL V2 (6pin) batteries pictured below. The top battery is connected in closed loop communication to the inverter and they communicate and give me the SOC. My question is what additional benefit do you get from connecting the green com cables between all the batteries? I don't notice any additional or different info on the inverter display when the cables are hooked up or not. Do the batteries talk and better manage charge and discharge current between them to balance total system SOC better? Does this communication between batteries still occur even if the inverter and first battery are not connected in closed loop? Also, how do you know if the com cables are hooked up correctly as I've seen some installs have the com cable going out from the top com port and into the bottom com port of the battery below and then some have it out the bottom port and into the top port below? The manual is not completely clear in showing this either but I believe it should be from out the bottom port and into the top port below.
![Screenshot 2024-01-10 165432.jpg Screenshot 2024-01-10 165432.jpg](https://diysolarforum.com/data/attachments/188/188152-71ccfdca4f53eb38d0863f7d6899ea8a.jpg)
