digitalbanana
Hello,
I am a UK domestic consumer and have 2x US5000 PylonTech batteries installed, there are connected via the A/CAN port on the master battery (red square below) to a Ginlong/Solis inverter.
I am looking to try and read battery capacity using an RS485 connection to the B/RS485 port (green box below) but it seems that if the inverter is connected to the A/CAN port, then the battery will not respond on the B/RS485 port. If i disconnect the A/CAN port, the battery starts to respond on the B/RS485 port.
Does anyone know if my conclusion is correct (that simultaneous comms are possible), and if that is the case is there anyway to take local reading of battery SOC (directly from the battery) while the battery is connected to the inverter?
Many thanks
Many thanks
